2000 Rinker 340 - AC not working on Shore Power. But works on generator power.
REP
Member Posts: 10 ✭
My AC unit on my 2000 Rinker 340 is not working when plugged into shore power. However, it does work when I run the generator. The breaker on the panel box is not tripping. I have switched power supply lines and they both work when plugged into the other electrical input for the boat. So it is not the power supply lines.
Does anyone have any ideas on why this would occur? Thanks for your consideration.
Raybo3 - I would like to check the shore power connector on the boat when I go up this weekend. How do you take it apart?
MarkB - Just to clarify, there are two 30 amp circuits going into the port side of the boat. They are side by side. One is designated only for the AC. The other covers everything else. You can see them in my profile pic.
Explore - So how do you check the breaker? Get an electrician? Or can you check it with a volt meter?
Handy and MarkB - is there another breaker somewhere else besides on the main panel? If so, where is it?
well, after writing my post it was bugging me so i went out and got into the boat to look. the double breaker that's in the weather proof box was on. guess that's not the cause for my ac not working. oh well, i tried.
I don't think you have that. So I figure once your AC shorepower is plugged in and the breaker inside is turned on, you should have power. I would do exactly as explore7425 suggests. It's either a bad breaker or a bad wire, given that the AC runs when the generator is on and that you know the power supply lines both work on your house circuit.
I checked the power supply coming into the boat and took the plug in unit on the side of the boat off and checked the wiring - confirmed power at plug in.
However, when I took the panel off, there was no power coming into the breaker for the AC. I was not sure if I had a panel issue, junction box or something else. So I called an electrician.
After several hours, we discovered that there was a snap together electrical conduit connector that is located under the bench seat - and in an impossible place to see or find.
We knew that there had to be a break in the wiring at that point. But could not pull it in either direction - because we later found it was screwed to the subfloor.
We pulled the subwoofer out on the speaker system under the bench seat which allowed us to see behind the wall a little bit. There was a black snap together connector that was screwed to the subfloor. We unscrewed it from the subfloor and pulled on the wire until we could get enough play in it to work on it.
It seems that the AC draw on shore power was too much for this connector - it gets hot here in the summer in the South. So the white wire part of the connector melted just enough to cause a small gap in the connector piece on one of the 3 wires- thus separating the snap connector on just one wire. The width of the gap that was created was about the width of your fingernail. It was so small that we had to really inspect it closely to see the melted portion. That tiny gap allowed for power on the input side but no power from there to the breaker box.
I will try to post a picture of it later.
Why Rinker decided not to run a solid wire between the plug in on the side of the boat and the breaker box is unclear. It would have been much simpler to run a solid line between the two.
Hopefully, if another reader has the same type issue, you won't have to hire an electrician to find it!
We cut the line on both sides of the snap connector, removed it and reconnected the line with a crimp connector and manually crimped the lines back together. AC works fine now. And I am a little poorer and a little wiser!
Ray
2006 390
Previous 2000 340
