Generator backfires/sputters to a stop
All,
this weekend my genny (Kohler 5E) started acting up. it was tuned up this spring with an oil change, plugs, impeller and not sure what else.
It runs fine for 2-3 minutes, good water flow out the side exhaust, and then it starts backfiring (popping sound) and stalls out. the inline fuel filter looks fine and the gas in the bowl is clean. Oil level seems correct. Any ideas of what could be wrong? just wondered if there was something I could easily check before calling the mechanic.
thanks
Craig
thanks
Craig
Same symptoms here, after changing fuel filter and having carb cleaned, I changed the plugs and it worked like new
