For Sale: 1999 5.7 260 HP Engine- Blown head gasket
For Sale: 5.7 260 HP Motor- blown gasket, two valves with zero pressure, others 160. Out of 1999 Rinker 270 Fiesta Vee. Located in Northwest Suburbs of Chicago. Asking $2000.
Engine still in boat has a blown head gasket, available to be seen and heard. Zero compression on two and three, 160 on others. 1999 Rinker in clean, putting a new engine in it. Unsure on hours, clean condition, probably 500+, 260 HP, fuel injected. Am told it's worth $2,500.
Reply with questions. Engine will be pulled week of 6/22.
How can it be worth that much if it has all those issues?
They're also the less likely to lean out on a carb'd engine, making conditions right to blow gaskets.
Have you personally pulled the valve covers? My initial thought is broken valve springs and/or retainers, broken push rods, or totally collapsed lifters. The type of collapse that takes out a camshaft. Suspect of this because that area of the heads struggles for oil flow more than others.
Yes, fuel injection and manifolds. Is my understanding as its a full swap for repower to a 383.
