No fixing. They can be bought at www.fireboy-xintex.com. You can buy them calibrated to length or cut and calibrate yourself. If I remember right: 19". There is a sticker on top that shows the length.
Pretty sure they are 17" long, I think the number on the top is 17 346. You can access the waste holding tank sensor by removing the access cover under the port side seat. the fresh water tank is on the starboard side, the access cover is behind the ice maker
@Mully did you end up replacing your sensors? Same exact thing happened to me this spring. Both showing as empty even though I know the water is full and the holding tank isn't empty.... especially with a wife and daughter. I was thinking it was the guage on the circuit breaker panel.
https://rinkerboats.vanillaforums.com/discussion/5826/342-waste-water-tank-view#latest
