cabin switch panel no power
Hey, just purchased a 2000 rinker 242 fiesta vee w/5.0 mercruiser. Everything on the boat seems to work except the cabin switch panel (a/c, range/ outlet/ microwave/ etc.) I am just unsure if I haven't switched something on to get power to it. I have tried putting battery switch to 1,2, and both with no success. This is my first boat of this size. Just need help in understanding if it's something I am missing or if there is actually something wrong and I got hosed on the boat. Boat runs amazing otherwise. Thanks in advance to anyone who pitches in on this issue for me.
Best Answers
JC290 Member Posts: 706 ✭✭✭
That runs off shore power it's 110 volt. Plug in shore power and turn switch on. Doesn't run off battery -
Unless you have a gen set those things you listed require 110 volts. Some guys have bought small portable gens and use them off the swim platform. I use to own the same year and model great boat. -
Hamdog Member Posts: 247 ✭✭
Without a generator running or you are hooked to shore power, you cannot run the a/c, microwave, coffee maker, etc. However, your refrigerator is probably a dual ac/dc model and will run on the battery.
"Wetted" Bliss 2005 Rinker 342 - Black Hull - Twin Mercruiser 350 Mags - BIII's -
MarkB Member Posts: 3,989 ✭✭✭✭✭
If you put an inverter on the boat you could technically run the 110V panel, but your batteries would last like 20 minutes and be dead. There is no way a 12V system can keep up with the power needed for a stove or A/C. No boat can do that. The best thing would be to get a portable generator like a Honda and plug that into a receptacle to energize your 110V system.Boat Name: King Kong
So I can't have my a/c or stove, etc. while I'm underway. That's really annoying. That was half the reason why I purchased this type of boat for those conveniences. They should have told me that at the dealership. I'm very aggravated now.
Thanks everyone, lots of great ideas.
Hey guys, when I do hook up the shore power does that charge my batteries also?
power panel on boat or shore? I didn't see a switch to charge batteries on boat but then again I haven't found a lot of things yet. Still getting to know my boat.
Yes, as long as you have the batter breaker set to "on". The switch should be in your cabin, where all the other 110V switches are.
