Genset runs - but no electricity
I recently purchased a 2000 Rinker 340. It's had some normal issues that are expected, but yesterday we were on the hook when we wanted the AC. I flipped the breaker switches at the electrical panel, then turned on the genset. No electrical. I moved the switches back. Still nothing. I tried starting it with the breakers set for genset and then shore power. Nothing. It has a 5KW Kohler genset. Suggestions?
Best Answers
blackjack3 Confirm Email, Member Posts: 7 ✭✭
My 05 FV 270 has a main disconnect switch similar to a battery switch mounted above and backside of it.I had the same problem this spring when I went to use the genny and this switch was turned off.I guess when my dealer winterized it they must have switched it off because I know I didn't and it was fine last year. -
explore7425 Member Posts: 150 ✭✭✭
There are fuses on the unit as well. They are near the switch on the unit. You cant tell if they are bad by looking at them. You will have to test them with a meter.Bella Sabrina II 370EC
