Starboard motor burning more fuel than the Port motor
I own a 2005 Rinker Fiesta Vee with twin 5.0 litre engines with approx. 115 hours on them. I have notice that my Starboard motor is burning more fuel that the Port motor. I fuel it up yesterday and the Starboard motor took 53 gallons of gas while the Port side only took 33 gallons. 20 gallon difference seems to be a little much for me. I have installed new wires and plugs on both motors, I have also replaced the coil on the Starboard motor. Has anyone ever had this issue?
@patriots - these valves usually have yellow covers on them and look like regular ball valves used in plumbing applications.
Click on the picture below. The valve in the picture is the "balancing" valve that regulates flow between my two gas tanks.
There are also individual valves to shut off flow from either tank.
The guys have given you great reasons why there is an imbalance between your two tank levels at fueling-up.
IMO if both of your engine RPMs were similar at a fixed MPH.... say 3200 RPM at say 28 MPH then your engines are performing too similarly to account for a 20 gallon difference, hence the issue is not an engine but the other possibilities the guys were suggesting......Unless the 20 gallon difference happened over an entire season and was therefore a very slow change - but I doubt that, right?
BTW - valve handle pointing straight down = off position .....valve handle in line with the fuel hose = open....if they have been installed correctly LOL
Good luck! MT
