The next kohler 5e saga
                    I was on the hook for the 4th and the genny decided to act up. It ran fine for breakfast and we went to fire it up for lunch and no go. It barely turned over and then wouldn't turn over at all. I only get a click about evry 1/2 second but the starter is not engaging. Initially I thought I ingested water. So I checked the oil and it looked clean and was at the normal level. I then pulled the plugs and looked for water and nothing; followed by trying turn the motor over to blow out any possible water but again I only got clicks and no engagement. Plugs were dry and I couldn't see any signs of water. So I think I'm safe on the water side. I then went to electrical and pulled out my manual. I popped the cover off of the control box. The led 2 and 3 lit up when the start button was pressed as they should. I then verified there was 12+ volts to the k20 relay, and I showed power to the top terminal (there are 4).  I also showed power down to the starter solenoid. However I'm not sure if there is power after or how to test that?  Also I cannot seem to find the starter which I was considering jumping the solenoid to see if the starter engaged. Could anyone direct me where that thing is?  So my initial guess is it's the solenoid. Any other thoughts out there on what my next course of action should be?  Those starters are around 400 so I'm hoping it's not that.
Is this voltage drop normal when the starter is pressed?
