Trying to get a handle on what powers what in regards to my battery bank. The two batts on the left of the attached pic are 24s. The two on the right are 27s. Should I assume each of the 24s is dedicated to one engine only for cranking? If so would one of the 27s be connected to the geny or would both 27s be paralleled as the house bank? If I need to start disconnecting batteries to figure out what runs what via process of elimination I can do that, though wanted to first see what the collective wisdom was here. I'm clearly not familiar and am an electrical novice at best. Boat is a new to me 320 (2008). Thanks in advance!
One of those 24's is also for your genny. I suspect it's the one on the right. The two on the right should be deep cell and are your house batteries. The would power things like fridge, lights, TV, 12v receptacles etc.
Let's try this again.......one 24 for cranking one engine, the other 24 for cranking the other engine plus genny. The 27's SHOULD be just your house batteries.
As far as your battery switches, some boats are different and some switches are different, I'd have to see what it states on each switch (i.e. on/off/emergency/parallel etc.), however one should be for the engines and the other for the house. The switches allow you to isolate the house from the starting or run all your batteries in parallel in case the starting are weak.
Ray
2006 390
Previous 2000 340
Walleye, the DC volt meter is just for the house batteries.
As far as the switches, in looking at your pic, you have the same setup as I do and you are correct in your assumptions. It appears that you have something funky going on or hooked up incorrectly.
Thoughts on what could be the issue here? Are the starting batteries not providing adequate amps to sustain my fridge and/or TV/DVD while on the hook even after just an hour or two?
For reference, my 27s are the 27M6's listed here: http://www.atlanticbattery.com/category_v3.aspx?categoryID=48
I had a similar issue, I could tell my fridge was not as cold as it used to be when out on the water, and the radio and amps would cut out after having it turned up for a while. Once I replaced them we are good to go.
Ray
2006 390
Previous 2000 340
