2004 FV 250 - Trim tab control box location??
I just picked up my boat from the yard, and find that the port tab is not functioning. I have read that there is a control box somewhere, but I have no idea where.
Anybody have any helpfull troubleshooting advice and can tell me where the controller is?
Thanks in advance!!
So I take it that I just remove all the screws on the face of the switch panel and lift it straight up? The controller will be down there somewhere?
When I talked to the rep, he told me that if I couldn't find the splice at about 6' (which could mean that it was installed at the factory with much longer leads) to cut the wire a apply power directly to the cable. If not movement at the tab, the actuator is bad.
Mine was bad and I have replaced. It sounds much better than the starboard tab now! I pulled the radio out and the controller is sitting in just behind there.
