265 Fiesta Vee Anchor Roller/Bow Roller Fluke Anchor
K&S2015
Member Posts: 18 ✭✭
Hi everyone. I need some help. Does anyone know who made the anchor roller or bow roller for the Rinker 265 Fiesta Vee? I think it may be the same one on the 266 model, and I suspect others too. Mine got all krunked up when some racing boats raced past the boats docked out near the castle in Alexandria Bay, NY as I was letting off my lines. I got the old one off and I think I did a pretty good job of straightening it out, but not as perfect as I would like it. I have seen so many rollers online and cannot match the one I have. I would prefer not to have to fill in old mounting holes and redrill new ones. I guess also does anyone actually have a parts manual for the craft, because I think that would help a lot in order for those that still have/use the boat to resolve things like this. Salvage Yards for boats?? I can get more measurements when I get home with a calipers.
My roller has four countersunk screws that hold it in place and I think the roller was 3" with a welded loop on the end.
Thanks everyone.
"Not my boat in image, just another one that has the exact roller.
I think I have the same roller as you on my 242. Someone hit mine and bent it a week ago. I haven't had time to try and pull it off and try to have it bent back. Let me know if your able to find one that matches, I'll do the same.
https://www.amazon.com/gp/aw/d/B00WFJBACQ/ref=aw_wl_ov_dp_1_2?colid=Q56BTQBFSJC4&coliid=I806LZVRIXG1S
This is exactly mine. In fact this is how mine was bent up too. Maybe a little worse than yours. I got it pretty straight now, but not as perfect as I would like it. I am working with a Rinker Tech to find out the correct one, who made it, and how to get it now. Looks nasty when it looks like that.
Yes, they were. I plan to reseal them by squirting some marine sealant through the mounting holes as I insert the screws back through. I bought some larger stainless washers to put back in there too, because the old ones were a bit pressed. I wanted to spread the load out a bit more.
Yeah, one of the screws I turned on before I realized what was going on and had to explore to figure out that there were 7/16 nuts spinning around. The others I unscrewed with the wrench in place. Two came off still in the box end of the wrench, but two fell into the pulpit. One of the washers is still hanging by some silicone, and one is firmly stuck in place by the silicone. The hardest part for me once I figured out using a wrench duck taped to some 1/2" PVC pipe was getting my wife to hold it in place. I had to keep going back down in the cabin to reset the position. She is not a mechanical type.
Exactly - I honestly wouldn't even bother trying to get a new one. You can fix that up, and then you know the screw holes line up perfectly. If you get on it now, you probably will have it fixed up and back in by tonight. Not a big deal.
