Big Orange install
I just ordered a Big Orange filter and plan to install it this weekend assuming it arrives by then. Looking for guidance on the best way to attach the filter and where. I have an '08 320 and there is a decent amount of space next to the holding tank thankfully. I'm hesitant to screw it into the tank directly as I've seen others do. Just doesn't seem like a tank you want to put holes in! Thinking about affixing a piece of 1x8 wood to the side of the tank or perhaps to the side of hull (inside clearly) next to the tank using 4200 and then screwing the filter into the wood as opposed to the tank or the hull/fiberglass. Thoughts/recommendations?
you will be glad to did it, regardless of which method you choose....
