Oil PSI reading at 4000 rpm 350 Merc- 2009 Rinker 280 EC
Second time out on the boat. At idle I am getting about 35 to 40 PSI reading. Between 3000 to 4000 rpm it jumps up to about 55 to 60. Is this not high?? I am a new boat owner. Engine has 30 hours and running with 25W-40 fresh oil.
Took delievery when the boat had 27 hours. I was told that it was winterized....however could not get the service orders. They tell me that the gear lube was done and a oil change was done. As the boat it was sitting for about two years, I did a oil change before taking the boat out. It came with a 3/4 tank of gas, so I filled it up with high octane and will run it for 5 or 6 hours and check the fuel filter for water. Am I missing anything?
