Fuel Tank
Having to remove fuel tank from 2000 vista vee. Can it be removed from engine compartment? Thank you! Greg 270-223-8343 Ky
Here's what I received from someone that's worked with Rinker: The engine will need to be removed to get the tank out through the engine hatch.
The firewall will need cut out for access along with the aft cabin floor.
Once you have access to the tank, the fiberglass straps holding the tank will need cut so it can be moved back and out through the engine area.
This make sense? Thanks, Greg
