Chain locker
frenchship
Member Posts: 1,079 ✭✭✭
Still have the same problem with my anchor rode and chain piling up and jamming my windlass. I did follow Al advice and remove 10 feet of rope but still same problem. Does anybody has the same problem with a 300 express 2007. The rope and chain are standard equipements .
Thanks
Thanks
Thanks LaRea
Paul
Lake champlain NY
Thanks
Paul
Frenchship you can purchase swivels of a quality that will match the loads of G4 chain. Just letting your rode unfurl once in awhile should work fine, if not you could try a cheap swivel to see if it helps and if it does put the $ down for a high strength one.
http://www.jamestowndistributors.com/userportal/product.do?part=226823&engine=adwords&keyword=product_ad&gclid=Cj0KEQjwrJ2tBRD13N7T5u7k9I8BEiQA5APAADDEGeJL4_jwOQBWP8Ergmrijn_Rbz2uk_g1g8NHM2waAg9y8P8HAQ
