2005 Fiesta Vee 270 - Fresh water leak in Front bunk Starboard side under mattress
Summerrental
Member Posts: 35 ✭✭
I have been getting water leaks in my front cabin for a while now. I can't seem to find where it is coming from. The water seems to collect under the mattress mostly on the Starboard side,.. but it also seems to happen on the port side sometimes (less frequently). Its always after it rains or washing down the boat, so I know its coming from above somewhere. When we list up the mattress in the front there is a small section of vertical hull with a foam backed white pleather material. This is usually completely soaked, so i am guessing it is running down the hull from somewhere above.
My suspect is the rub-rail,.. is this common to occur? I have heard the rub-rail is very difficult to re-install once removed so I have not attempted it yet. I noticed a small leak from the port hole window in the center of the ceiling but I fixed this by re-securing the screws. Can this be coming from the anchor compartment in the front and running back?
Just wondering if anyone else has had the same issue since interior water leaks seem to be a common flaw in Rinker boats.
Side-notes for other Rinker owners:
1. For anyone that is having leaks under the floor carpet just outside the head entry door.... I had a very small water leak coming from one of the plumbing fittings below/behind the sink inside the bathroom. Once I removed the plastic cabinet under the sink and inspected it, I had it fixed and the carpet stopped getting wet.
2. I had a leak in the Aft cabin a few years ago that caused the entire ceiling foam padding in the aft sleeping area and to fall down! I later confirmed that the 4 cup holders topside did not have drain tubes and when the rear canvas was not up (which I don't always have up). The rain water drained through the cup-holders directly onto the ceiling of the aft cabin!! Once I installed drain tubes, never had a leak again. I find it horrible that Rinker did not install this in the factory. now I have no finished ceiling in my aft cabin,.. My guests get to look up at the fiberglass as the sleep... Nice Rinker.
Here's what I recommend.
Take a hose and spray at the base of 1 rub rail post for 5 minutes. Be careful not to wet other posts, so you can isolate the problem. Check inside. Depending on the size of the leak, it could take longer than 5 minutes for it to appear, so give it time. Patience will be key.
My guess is it is one of the rub rails. Someone on this site recommended drilling a small hole into the bottom of the rub rail post, which would relieve any accumulated water. Let dry, and then fill the base of the post with some marine sealant. This would be a whole lot easier to do than to remove the rub rail. So I would try this technique first.
Home port: Hammond Ind.
Ihave same problem on my FV 270 -02.
I wounder same thing about the rubrail.
