2011 Rinker 260 EC Planing Issue
I recently took 6 adults and one child on my Rinker 260 EC which is equipped with a 350 Mag Bravo 3. It has always been a bit sluggish getting on plane with a load, however, this time was virtually impossible and we had to end up turning back. We did not have a full fuel tank and our water and waste tanks are mostly empty. At 4000 RPM's with trim tabs down, the boat would not plane and I was getting some "slipping" sensation in the prop shaft and a little bit of exhaust backfire so I throttled-down so as not to push it too hard. Even trying to adjust the load forward in the boat I ran into the same issue. The engine and sterndrive are maintained regularly and I just had the propellers refitted this year using PropScan. I am hoping this is not a problem with the engine coupler or propeller shaft. Anyone have any suggestions before I consult a mechanic?
With trim tabs down and drive trimmed all the way down I was able to plane in about 20 seconds.
With 3 adults and 2 children I am able to plane in about 8 to 9 seconds.
So it sounds like something is wrong with your drive.
I believe the boat that required modification is the 250 EC.
Good point jhofmann. I have 22P props. No doubt they get me out if the hole fast but my top end speed is 40 mph. I cruise at around 29 to 30 mph at 4100 rpm.
