Bilge electric floor lift
I've got an electric lift that brings the **** up and down to access the bilge. It operates fine, but makes an aweful crackling noise going up and down. Is this operated by a worm gear or something that can be lubricated? This is the only thing I can think of that would make such a noise. Thanks
If you decide to just grease it and live with it a while you should probably pay attn to how youd pull the pin if it gave up in the down position.
Mike
I'll try to find the grease fitting this weekend.
Load rating
Stroke length or model number
Thread pitch (inches/minute)
Make sure it is marine rated too.
