Transom door latch
pearson57842
                    Member Posts: 31 ✭✭
                    The plastic insert that is in the stainless receptacle for the transom door barrel bolt has cracked and the bolt now rattles and won't stay locked.  Does anyone know where to purchase a replacement?
Pearson57842: Your original question sounded like it was regarding the receptacle that the latch fits into when the door is closed. Correct?
If so, I have the same problem. I was thinking of trying some of that rubber coating stuff that you can put on hand tools.
Here is the link to the PCV valve grommet fix that works great for the receptacle when the door is in the open position:
http://rinkerboats.vanillaforums.com/discussion/comment/13650#Comment_13650
Ray
2006 390
Previous 2000 340
http://www.homedepot.com/p/Crown-Bolt-5-8-in-Black-Neoprene-Grommet-73588/202210007
06 Rinker 270
Part#: Dorman 42058
