Having a fuel tank emptied
olemiss89
Member Posts: 6 ✭✭
I'm having water/fuel issues and after changing filters and dumping them several times and adding blue stabil to the tank I'm still not getting my starboard engine to stay running. Has anyone ever had their fuel reclaimed, tank cleaned and start over? I feel like it is a last resort but also maybe a quicker fix at this point. Does a tank really need cleaning as well?
Thanks.
Thanks.
It was slow going and obviously you have to be extra cautious around gasoline fumes due to the explosive potential. You simply cannot have anything nearby that will generate a spark, even static electricity is a hazard. So first put out the stogie!
That old tank of mine was junked, but I imagine if the input hose is at the lowest point in your tank it will pick up the sediment in the bottom, and then you can flush thoroughly with fresh fuel.
Andy
