Help lost keys and a long way from home
Wildboating
Member Posts: 957 ✭✭✭
as title says, lost keys somehow and I'm literally on a island Help?
Try removing the ignition switch panel and finding the hot wires on the switchs.
Their should be two other position on the switch. One for run and one for starter.
Connect hot wire to run wire and then hit them to starter wire should get you going.
Finding which wires are which will require some experimenting.
No garrentee but just a thought.
Len
Len & Robyn 342 FV Freebird
When you're back home, get an extra set of keys made and stash them somewhere on the boat. We've all lost keys, don't feel bad.
Andy
As far as what Al stated, (correct me Al if I'm wrong), take the 12V & tie it to ignition and then tap it to yellow until it's started? Sound correct? I was just playing with a friend's ignition two weekends ago (one engine didn't crank) and for some reason, one engine wire made it to the solenoid, but the other motor hadn't. We checked breakers and such. He made me stop helping and go back to the admiral to enjoy my evening! But yes, there were only 3 wires as Al stated.
Andy
Re: "I can start 100% of every boat made...." Al, are there any court sealed documents of your youthful escapades out there? LOL
