Exhaust system, dry joint gasket issue. Merc 2003
I need to replace the gaskets on my exhaust system since the PO of the boat didn´t install it the right way.
However, I find contradictive guidelines on the web on how the should be installed.
I have a sea water cooled dry-joint system with 3” spacers and some schematics indicates that the gasket with the restriction should go on top of the spacer and the full flow gasket on top of the manifold and some indicates the opposite.
Two contradictive examples:
http://boatinfo.no/lib/mercruiser/manuals/mercruiser37.html#/104
https://www.youtube.com/watch?v=3ChXrMNVexY
Can anyone please sort this out?
Thanks
Best Answer
auqalolic
Member Posts: 4 ✭
That's correct, the restrictor goes on top of the spacer and the full flow goes on the bottom. I just replaced my manifolds, risers and spacer kit, it was a piece of cake.
