AC on my 2007 280 EC
So this is my first boat with AC in it. Boat does not have a genny so the AC only runs when connected to shore power. I turn the AC on and it runs until it meets set point. It meets set point and then turns off. I turn the set point down a couple more degrees (have the cabin door open going in and out) from 70 to 68. And the unit does not kick on which seems like for a special timed amount. I haven't time it but it seems like its between a half hour to an hour to where it won't kick on. Is this normal
I originally thought the strainer was plugged which was causing it to ice up, but I checked the strainer and it wasn't bad at all, still cleaned it though. Ran it again Friday night and it does the same thing.
Any insight would be much appreciated.
Boat Name: Knot A Worry
