Motor to lift engine hatch
anyone know where I can buy a new motor to lift engine hatch on 342 I had it rebuilt once and it's moving so slow again could not find a new one that's why I had it rebuilt
2002 Rinker FV 342
    Did you try this company.
    These are virtually worthless to 'overhaul'.  Spend your money if you want, but it is a waste.  You need to replace the whole thing as an assembly.  Acculift is OK, the product takes up a lot of room and pulls high amps.  You can go with a better solution as long as it is ignition protected..all you need to know is voltage, AC/DC and voltage, stroke length, force (pounds) rating and the inches/sec travel speed (not a big deal for this application).  That one is 12VDC, 24" stroke, 250#
    You can get better ones with built in stroke limiters (running to end of stroke is NOT good).  Even ones with amp monitors that prevent the actuator from retracting and say crushing a limb.
    www.warnerlinear.com
    Lenco also make actuators
  • Dream_InnDream_Inn Member, Moderator Posts: 7,833 mod
    Yeah I have one for my rear hatch that is giving issues.  I need to buy one as well.
    That's another thing I love about the 400s you can put a small car in that transom locker, geez its big!
    I hear ya MT.  I currently have 4large fenders, 8hp outboard, inflatable SUP, large anchor with 150ft rode, (usually inflatable kayak, UT it is under vberth for front weight for our trip).  That doesn't include all stuff under rear seat which is all connected.  Gotta love it!
    My transom locker is green with envy!
    BTW, I found the issue with my rear hatch.  After tearing apart the motor and checking the bushings, all was fine.  I then checked voltage at the motor, hmm.  Checked it at the switch, was fine.  Ohmed the wire, missing one.  Under the engine hatch, one of the wires was pulled from a connection.  All is working well now!
    Nice catch - that would be about $100 in labor at the dealer to find.
    thanks! Probably would've been $200, cause I was about to have the motor refurbished for$100, then another hundred to find the wire.
    I'm pretty shure my problem is the bearings in the ram that lifts not the motor
    2002 Rinker FV 342
