Swim platforms extremely slippery?
Shelby
Member Posts: 21 ✭✭
One boat is a 1998 330. Other one is 2003 312. Both have very slick platforms. Has any else experienced this? Any remedy? Thanks Shelby.
2005 320 Twin 350 Mags MPI Bravo III Lake Cumberland, KY.
Best Answer
MarkB
Member Posts: 4,000 ✭✭✭✭✭
Shelby why don't you test something with an adhesive backing like ordinary tape. If that works you know seadek will work as i believe they use 3M adhesive backing.Boat Name: King Kong
Yes I had the same issue. I have 2004 232 Captiva BR. My boat has a swim "extension platform" and an integrated swim platform, which is standard, if it wasn't ordered with the swim "extension platform". It was dangerous standing on both out on the water, so I put Seadek on both platforms, including the walk through.
This was one of the best investments I have made on my boat but it wasn't cheap. About $600 for both. Family and friends that boat with us are impressed with this being added for safety, and they comment that it "looks cool" too. I will add pictures on another post. Seadek is an awesome solution for this purpose. Check out other posts on this site about Seadek or go to Seadek.com.
Rob
Dave
Ray
2006 390
Previous 2000 340
When you use it do you have to scrub? Or can you just spray it on, let it sit then rinse it off?
When the Admiral uses it in the cockpit to remove bug and spider cr*p off the seats canvas and gel coat she mixes it with water in a spray bottle as the P.P. is pretty concentrated in the bottle. When I do the non-skid I wet the area first, put a small amount from the bottle on the scrub brush then scrub it around. I let it sit for a few minutes then hose it off. It works great -bird and spider droppings and ground in bugs all come off as do the dirt marks from the techs boots - which they are SUPPOSED to cover with "booties" or remove - yeah right! LOL
Is there a certain wet vac you guys use that is spark or ignition proof?
06 Rinker 270
I may be corrected shortly but when cleaning in the cabin or in the cockpit we use a small Shop Vac model that is 110v for bigger jobs and a small 12v dust buster for small jobs (mosquitos etc.). We have a built-in central vac but I find it too much effort to use. If we have been away from the boat for a number of days I run the blower for 5 minutes and open-up the hatches before I plug-in any equipment. That's probably OCD. However, I also use that Shop Vac to remove water from the bilge. When doing that the Shop Vac stays on the cockpit floor - it NEVER goes below floor level into the engine bay/bilge area. I use two extension wands to add to the length of its oem hose. I also run the blower for 5 minutes before I vacuum the bilge water. I picked-up the small Shop Vac at Walmart. It fits under the front seat and works great.
