Trying to decide on new prop
KYSEAN
Member Posts: 121 ✭✭
My boat runs 4900 rpm WOT with a 3 blade 21P aluminum Mercury prop. I would like to get just a bit more hole shot for water sports. Mercury suggests a 21P Rev 4 SS. Others suggest a 20P Alpha 4 Alum. Big price difference. Pros and Cons of both? thanks, Sean
2012 Rinker BR216 5.0
fwiw, I just re-propped, dropping from a 14.25" 21p 3 blade aluminum to a 14" 20p four blade aluminum.. the four blade absolutely raises the transom, and it is a lot more 'solid' a bite, for lack of better description, on plane.. I can also hold plane a good bit lower in speed, which is from 20~21mph w/ the 21p/3blade to 16~18 w/ the 20p/4blade.. that is, if my speedometer is to be trusted..
just a suggestion, but I would recommend if you don't have a prop shop that will allow you to test run the prop, to buy an aluminum prop to select pitch/blade.. once you dial it in, you can likely match it up with a s/s model- but realize the s/s version will lower your RPM's slightly, and not flex into the bite like the aluminum will.. translation: if you're happy with the aluminum version of the prop, you'll likely be more happy with the s/s version of same specs..
where do you run your rig most often? if in sandy environment, the s/s will hold up much better when you inevitably strike bottom.. the aluminum will not.. if you're in a lake or some such with decent depth, and rocks are the obstruction, ain't no blade going to hold up to hitting that..
edited to add: I wish I would have kept the same diameter @ 14.25" with the new prop, instead of dropping to 14".. I can feel some slip out of the hole that I bet spinning a slightly larger blade would fix, and I don't -think- it will tax the motor much more if any to do so..
2019 MTX20 Extreme
Dave
I run a 19p 5 blade stainless for watersports. They are expensive. I have run the alpha 4 blade 20p and it is good coming out of the hole.You will lose some top end though. I also have a 5.0
Dave
Dave (nhsd),
You say you want to get your planing speed down. Do you have a set of SmartTabs (or any tabs) yet?
Mark
2019 MTX20 Extreme
Dave
Check that... It's a 21p and its $390 with shipping.
Find your local Merc dealer. Merc does have a trial or loaner prop program. ( may be limited sizes)They should also be able to get you pretty close to what you need.
You can also send your prop to one of several prop shops for some extra cup or in some cases re-pitch.
Tabs of some sort will REALLY help you get on plane. I installed Smart Tabs on my 03 232
