Recently purchased a 2005 282 captiva and the fridge is not getting cold. Need help troubleshooting.
Upgraded from a 232 captiva to a 282 captiva so this is our first boat with shore power. Shore Power is plugged in and there is power going to the fridge as the light inside goes on when fridge door is open...But Fridge is not getting cold. We have the dial on and turned to the coldest setting. What else do we need to be doing or checking? There is no on/off switch anywhere on the dash or battery panel for the fridge...only a fuse for the fridge on battery panel.
Is the light inside the fridge flashing at all? If the compressor is not coming on due to a fault, the light should be flashing. The number of flashes will tell you the fault code.
http://www.rpc.com.au/pdf/waeco_coolmatic_CR65-140_manual.pdf
Handy, see page 39. There's two lights by the t-stat. Green = good, Red = fault. I see it from the front of the fridge.
