CO-2 fault on Kohler 7.3 ECD
ok, here is the story. This past weekend my generator shut down, looked at the alarm and it said under frequency (UF). This happened when the admiral turned on the air conditioner (generator had been running for a while at that point, just on a medium load). So, I looked at the strainer first, ah, was pretty full of seaweed. Wasn't sure why I wouldn't have gotten LOC alarm instead. ok, started it back, was fine. Added A/C down she went. I believe I got UF one more time. Next time it switched over to CO-2 alarm. At this point, it will first give CO-4 and then shut down with CO-2. To me it could be a couple things. Either too much backpressure from the catalytic converter or the CO sensor board.
I will say, I've done some reading and saw someone have very similar issue, UF alarm. & they changed spark plugs and all was good. So, I've changed the plugs and also looked all the exhaust lines (removed and inspected with soapy water in case of CO leak - but had digital CO detector next to genny and definitely not a CO issue). I have not ran it since. So, keeping my fingers crossed, maybe I'll get very lucky and it is the plugs. I will run it tonight.
Any one else have similar issues or suggestions?
What's really funny is I just did a search to see what the cost of a coil is (so I know when I get my repair bill that it's close) and this is what came up:
http://rinkerboats.vanillaforums.com/discussion/1846/kohler-genset-issues-just-wondering-there-has-to-be-a-solution/p1
& of course reading it BD says that the coil is the first item to come to the top and most likely the culprit. Oh well, I don't take the boat to the shop very often and I just needed to get it working quickly! I've heard once you replace one, more than likely the other coil will go not long after.
Ras, once you get the admiral sleeping on the hook, there is nothing like it! run that genny and make her like the comforts of home while on the hook if need be! Once she gets hooked, it's all over! It's getting to that time of year down there where you can anchor all night and open the hatches/port holes and enjoy the breeze. Replace the enclosure now, instead of later and then not getting as much enjoyment out of it. (I've been there, and replaced all kinds of things years after owning boats only then to sell them and say "man, I should've replaced it years ago and enjoyed it a bit". It took till our 4th summer with this boat, but we finally got all new tables & carpet.
I can't wait to get on the boat on Friday and try that genny out! I'll enjoy actually having someone else do some of the fixin this time around!
