Speedometer Quit Working
                    I have a 2014 Rinker 310.  Recently, my Speedometer quit working on my Mercury Smart Craft Display.  My local yard told me the gauge reads water being forced into the lower unit as it moves forward through the water.  They said the intake holes and lines get clogged and are almost impossible to clear.  Has anyone else had this happen?
I'm currently using my GPS for speed but it's hard to see with these old eyes in the sun bouncing around the water.
2014 Rinker 310 Express Cruiser.
Had this problem when I got my 232 with B3 drive. Saw on Youtube to take a very small drill bit and screw it by hand into the speedo hole on drive. This will pull the blockage material out. Start small and increase size of bit until clear.
There is as hose that comes out of the drive by gimbal that goes to speedo, that has a t shaped fitting, to remove the drive. Twist hose off fitting and blow air back towards drive to push debris out like MT said. Common problem.
i was in sandy bottom
oh well can wait till fall
to get cleaned out
