2 beeps on my 2002 250 B3 MPI
The engine would completely shut off after it got up on plane...But it would run at low speed and was able to get back to the marina....Tech found it was the shift interrupt switch which was loose not bad....just for your info
Al, still having a problem...Tech says its not recording in history code...I have been out with him and his computer plugged in now 3 times for at least an hour at $110/hour and it doesn't happen...I leave him go out on my own and it shuts off after on plane....He now thinks its an electrical problem...When this all started they replaced the plug for the fuel gage in the helm...He is now going to check the wiring in the dashboard...
When I went through my overheating problems last year, my engine never stored any fault codes. It would beep and go into limp mode, but it never stored anything and never showed a fault on my MercMonitors. As I later found out, the fault was the exhaust manifold cooling temp (EMCT) rather than the engine cooling temp (ECT). Apparently that sensor plays by different rules.
