Fresh Water Pump
I have a 2005 250 fiesta vee. When I turn on the helm switch nothing happens and the switch light doesn't come. Is there a fuse or any idea of the failure??
Fira, the water switch is in the cabin. Mine is next to the head and it's called Galley Pump. Make sure your water tank is full and then turn on this switch. Once you open the tap, the water should start coming out.
As for the lights, what light switch are you turning on? What is the label on it (Cockpit, Transom, Spreader, etc), they each operate a different circuit. There's some inside the cabin as well, my switches are next to the head as well.
Finally, yes, there are breakers for EVERY factory installed circuit on the boat. Some breakers are located under the steering wheel. You will see like push botton type breakers. Other breakers are in the battery switch panel, next to the gateway at the back of the boat.
I assume your batteries are charged and the battery switch is on??
i have a 2006 270 and I have a Galley Pump switch at the helm.
The light on he galley pump switch comes on when activated.
Upon activating you shold here the pump working.
If the pump keeps running, it could mean a couple things. Maybe your tank isn't full enough to prime the pump. Try filling the tank all the way to the top. Or you might have a loose fitting that is letting air into the pump. Or, worst case, your pump is failing.
Some boats use tank water for the toilet, and some use raw water. Turn off the pump and flush the toilet. If it still flushes normally, then you have a raw water flush.
