Squeaky sound
watermark
Member Posts: 16 ✭
When I took my boat out this weekend I noticed a squeaky sound from the engine - I own a 2014 Rinker 196 bow rider with a 4.3 Mercury Mercruiser inboard motor - I only have 30 hours on the boat. I stopped the engine and checked the oil - which was a bit low and topped it up but the noise was still there. Then I thought the fan belt may be a bit lose but it seemed tight. I also noticed my oil pressure was a bit high as well. Not sure what to do. Any advice is appreciated!!
Thanks!!!
Thanks!!!
Mark
2019 MTX20 Extreme
Could be the belt. How do you know it's tight enough?
Take a close-up look at your belt -- any unusual wear? Look on the floor under the engine --- any little "crumbs" of rubber?
You might consider installing a new belt. If the noise goes away, problem solved, and you can keep the original belt as an emergency spare.
As noted, being new, make a warranty call.
