Removing floor under cabin table.
Hello thinking to put in an bow thruster , i wondering how i can take of the floor in the cabin where the table is.
Its an fw 270 from 2002.
Swede:
Are you really sure that you need to place it under the floor?
In mine, only a 250 (2003), the thruster is installed in the most forward storage compartment. The thruster is a Side-Power SE40s.
No need to remove the floor and easy to access, service and most of all, inspect. Well below the water line in order to work efficiently.
Two pics for illustration.
No problem when its blowing Pam?
It would be perfect if its fits in the same place .
I looking to same side-power. how long under the waterline ?
The PO installed the thruster and the boat is still in the water. Can't measure. My guess is that the upper part of the tube is about 15 cm (6 inch) below the water line. Three pics attached as reference.
Have never had problems with the thruster loosing grip even rough sea.
Sounds good hope i can fit in bow thrustern on same place.
Thank you for the pic´s
I’m not sure if this will help you in Canada, but anyway:
The installation were done here in Sweden in 2012 by the previous owner. I have no knowledge of the labour cost for the installation but the cost for the equipment was roughly 1400 USD, back then.
Does it work? Does it move the bow well?
Do you know what size motor that is?
Looks like a great job.
I see that having a bow thruster on your boat still hunt you
but now with the CDN $ at almost 30% less it would not be a big saving.
Paul
It moves the bow verry well even in heavy side wind.
Below you'll find two pics with specs from a SidePower broschure i have. In it I believe you'll find what you were asking for. (the SE40)
I have also uploaded the entire SidePower PDF (from 2014) to my dropbox :
https://www.dropbox.com/sh/5k9w770gy1j1hxz/AACIf9C0edAKgOh6gyeTRK_1a?dl=0
I'll keep it available there for a about a week.
here are some pictures of of Rinker 260 with a bow thruster.
actually I don't know who did the work, my friend was looking at this boat, but I guess if yo contact the seller you could find who did the installation. It was on boats.com
the seller is
2007 Rinker 260 Express GEN Thruster
Boat Details
Measurements
Propulsion
Other Specifications
Description
Yet Another Price Reduction!! Motivated Seller!!
Talk about FULLY EQUIPPED!! Here is a trailerable Express Cruiser with a FULL list of Hard-To-Find options!
Kohler Generator! Bow Thruster! Reverse Cycle Heat and AC!! Anchor Windlass! Remote Spotlight! Automatic Fire Suppression!
Powered by a Volvo 5.7 OSi with Fresh Water Cooling and only 170 hours, she was hauled and fully inspected in April 2015. Full Canvas Enclosure, Dual Shore Power connections, and much more!
Please check the Full Specs for more detail or give us a call to schedule an appointment!
