Dinghy Ramp Davit System
I own a 320 and was wondering if anyone uses the Dinghy Ramp Davit system on their swim platform. I am now using the Weaver Davits. They work well but it is a pain to always take the motor off. I also do not have a fuzzy feeling about placing the motor in the boat. I do not put the motor in the compartments for fear of a gas vapor issue but even the fact that it can topple over in the cockpit on the way back to port and hurt someone scares me. They are expensive but I use the Mercury 270 Airdeck almost every weekend.
http://www.dinghyramp.com/
Several people around me have the one you mentioned. Trick Davit is another - I have this one but it's not very good for a RIB, a soft bottom would do fine.
I just removed my Trick Davit. Replaced it with a Hurley H3O pull on type. Should have bought it to start with. Effortless.
The Hurley H3O has no painted metal.
The Trick davit did not at all fit the hull of my AB. Actually dented the hull towards the transom on mine. grrrrrr. It was near impossible to pull the dinghy up, mostly due to the deep-v hull on the AB.
Just my experience with a 342 and an AB 9.5AL.
