350 MAG MPI over heating
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
Had my 342 out for a run today. Ran maybe 5 min at cruise and the over temp alarm went off. Throttled down to idle, temp dropped from 180+ to 160F fairly quick. Stays at 160 unless I run at cruise then right back up. Impeller is new this spring. Ran fine all season. No sand injestion. Thinking thermostat? No leaks. Fresh water cooled. Thoughts? Got 1 week to fix it before I haul out.
Best Answer
Black_Diamond
Thought I long ago answered this one. The tube going from the drive to the transom plate (new hose that year) got twisted during installation. Eventually it just collapsed or got blocked. The new hose kit has the hose end going to the transom as a solid piece so it cannot get twisted when installing. All happy now! Plus new Jardin Marine SS water pump.Past owner of a 2003 342FV
I forget -- does your boat have thru-hull water intakes? Could this be the infamous Bravo 3 intake hose problem?
@Dream_Inn - yes, remove the nut and pry off the cap with a screwdriver. There's a rubber gasket, but no gasket sealer. Easy.
The typical symptom is that there's enough water flow to run at low to moderate speeds, but the engine will overheat above a certain speed. When it overheats, if you slow down to idle, it will cool down quickly.
The speed at which it overheats will depend on how badly the fitting is corroded. Mine would run all day at 3200 RPM, but overheat within minutes at 3400 RPM.
Some boats are plumbed with a "dual pickup" system: the Bravo intake hose plus a through-hull. Those boats are less likely to have this problem.
BD, I have seen exactly this symptom caused by water supply hoses that have lost their integrity on the supply side of the engine so that there is enough water flow at low rpms but the hose gets sucked in at higher rpms. Also have seen obstructions in the water exit lines (think burned flapper or impeller parts)(that have obstructed flow at higher rpms again causing rising temps. If your sender, thermostat and gauge are ok I'd look at the hoses.
All of those blue drain plugs are original, should they be replaced at some point due to age?
