Dual Battery Switch Operation
New Rinker Owner here with a Captive 232 CC. Dealer told me to switch batteries to '2' before starting and operating the boat. After using the boat switch back to 'off'. Two questions, is turning the batteries off at the end of a trip needed and is operating on both batteries all the time correct?
Thanks,
Randy
Not sure about that procedure bud. If you are wired same as my boat, #1 keeps both the house circuit and crank circuit separate. #2 bridges them together. It is never a good idea to bridge both circuits unless your crank battery dies on you and you can't start the boat.
Second thing I was told is never turn a batter switch while the engine is running. This can create surge which will blow the isolators.
Anyhone want to chime in and correct me if I wrong. I'd really like to know.
We are getting a little off track. First both batteries charge no matter the position of the switch. Second, If you are on the hook you need to shut the boat down then switch the battery switch to on e or the other (my deep cell is on number two) if both are cranking batteries it doesn't matter. The when you leave turn the boat off and switch back to the other battery to ensure a good start. It is a correct statement not to switch battery positions while the boat is on. I did this one time by accident while just the ignition was in the on position and blew a fuse.
Now, I used to run on "both" all the time until when on the hook. This is until someone brought up the fact if your alternator goes out underway you will have no reserve to get back home.
I think everyone is on the same page here just explaining it a little differently.
2019 MTX20 Extreme
2019 MTX20 Extreme
Any one use one of these? You don't get the voltage drop like you do with isolators......
http://www.bluesea.com/products/7610/SI-ACR_Automatic_Charging_Relay_-_12_24V_DC_120A
Mark
2019 MTX20 Extreme
I have a 2000 242 fiesta vee. Mine doesn't charge properly on either battery from what I can tell from the voltage gauge. barely gets to 12 volts. And as soon as I use anything especially the spot light or trim tabs it drops all the way down to 9.5 volts. Doesn't seem like a good thing to me. All of this is very confusing to me (first time larger boat owner) I have never had a 2 battery system. Would love to just have someone give that ahha answer. It would really help to get absolute clarity on the answer. I have only owned the boat for 2 weeks and really not want to start with major upgrades. Changing an alternator is the issue. That's and easy fix. Already had it off once. If this was a pick-up truck that would have been my first move seeing since I have 2 brand new batteries on this boat. But it's a boat and I know from reading all of everyone's post that it is very possible it could be a wide range of other issues that I have no clue about. Thanks for any help. Clint
