Mercruiser B3 XR props for sale
Have a matched set of Bravo 3 XR 21" props...front prop has 4 blades,rear has 3 blades.
Equivalent to a 22 " regular pitch prop. Great hole shot. used for 10 minutes as back up props.
$500 or b.o.
$500 or b.o.
do not need them.
No, the new Sea Ray has B3 outdrives..but prop pitch would not work with
the new drive.
Utilizing the same mounting hardware these new propellers can be used on standard Bravo Three, X and XR. Recommended to run on big boats with big power (496 through 525HP). Enormous cup is built in to the trailing edges of both front and rear props offering tremendous planing performance in addition to some of the best mid-ranging cruising numbers you'll ever see. Top end numbers are generous for most applications and if you plan on switching from the standard Bravo Three (example 22" pitch) to the new Bravo Three XR (plan on running a 21" XR) to match the RPM of the standard 22pitch.
Designed for Bravo Three and Bravo Three XR drives
I was running them on a 04 mercruiser 350 mag mpi rebuilt to a 383 stroker
with thru hull exhaust.
