Water in oil and cylinders
Had engine troubles..hard to start, using throttle only button, starts up then dies, smell fuel, sluggish when execrating, engine died while in fairway underway. I had no time over holiday weekend so I called the mechanic to stop by today. Found water in oil, water in 3 cylinders, and said the exhaust manifold is cracked. Compression is good. He is taking home oil filter to see if he finds metal shavings. Boat ran fine before it came out of water to get bottom paint, outdrive paint, fireboy installed and fuel filters replaced. I go back in and immediately bad issues. Am I looking at a new engine or believe its just exhaust manifold? I got zero alarms, engine temp and oil pressure great all weekend.
Patrick
06 Rinker 270
06 Rinker 270
@LaRea no overheating, right at 170 all the time.
@Dream_Inn what happened in your situation? I do have a fantastic mechanic, finally. He went to boat less than 24hrs after I told him my issues which may have saved me from water corroding engine. BTW what do you guys pay for your mechanic?
06 Rinker 270
Could your riser have been prevented? I am wondering what I could have done to prevent mine. I thought the risers and manifolds were good, little did I know there was a crack forming.
06 Rinker 270
06 Rinker 270
06 Rinker 270
Oh and a little update, boat is running well. No more water in oil.
However, insurance is not agreeing with tech on faulty winterization. Oh well, I got OEM manifolds and risers, which was already on the list to do anyways. Only additional cost I was not expecting was his labor if I had done them myself. I am just happy to still have my baby up and running.
06 Rinker 270
06 Rinker 270
