How to install trim tabs on a 212 Festiva
Kennuck
Member Posts: 8 ✭✭
I want to install Bennett hydraulic trim tabs on my 212 festiva. Bennett has a tech article here http://www.bennetttrimtabs.com/tech-help-support/project-boats/rinker-captiva-232/ would the install be the same for my 212? The transom looks very similar.
the tabs were mounted as soon as the hull flattened out enough from the concave, which isn't as optimum as having them on the outer portion of the transom, but it's better than without. the smart tabs were worth it for the handling alone. they have no added worth at planing speed, though, as an adjustable tab would... I just can't justify the need for adjustable tabs, though...
Good luck, sir!!! report back how they work out!!
