Accidently put motor oil in the lower unit
So in my rush to finish winterizing last night I pumped motor oil into my lower unit (Bravo 3). I had pumped a half quart of gear lube then switched bottles and accidently grabbed a motor oil bottle. After pumping 3/4 of a quart of motor oil I discovered my mistake. So I drained the oil from the lower unit. Pumped in the remaining 1/2 quart of lower unit oil. I then let that drain in attempt to flush any residual motor oil. Then I put in 2 quarts of gear lube. I am still a quart of gear lube short and plan to fill soon. Is it likely that this will damage anything? Is there anything else that I should do?
Thanks,
MDboater
Thanks,
MDboater
Steve, I just relayed what my next door neighbour had done at a marina's suggestion about 10 years ago. He kept the drive for three or more years and never had a problem, so obviously that plan worked. Overkill? Who the **** knows? It worked.
As for other solutions, I trust Al's judgement.
In my case I have two new Bravo lll X drives. They will be under The Mercury Platinum Protection Program until 2022. If something like this happened I would take no chances and have the dealer get Mercury's solution, in writing, to avoid any future warranty misunderstandings. Even if it weren't under the MPPP "warranty" I'd probably still flush and re-fill the drive at least once, maybe twice.
these engines and gearboxes are not space craft you know
If it was a factor then. flushing the gear box is not enough..you should pull it down, and apart and degrease the entire gear box, then reassemble and fill. (only in NASA would we be doing stuff like this)
Thanks!! I used the Quicksilver 90W high performance gear lube.
