power loss misfire
mick
Member Posts: 2 ✭
hi I run a 270 rinker 5. efi
had an engine rebuild last year, engine runs sweet at dockside out side on the sea get to 3000 rpm wot. then back throttle off iac comes in pops and backfires and will not rev in or out of gear have to let it cool then limp back on tickover replaced map, iac, and thermo sensor ,scanned and no codes.cannot use in rough conditions for a fear of failure let it cool completely and it runs as if their is not a problem can use in marina in and out of gear fine no beeps no code faults.any ideas please regards .mike uk.
Post edited by mick on
well no replies on this problem
I'm sure you've seen the fault code list, but if not, look here:
http://rinkerboats.vanillaforums.com/discussion/1042/encountering-faults-check-this-out
In some Merc engines, there are faults that will activate Engine Guardian (limp mode) but will NOT store a fault code. For example, in my 496s, an overheat in the Exhaust Manifold Cooling Temp (EMCT) does not store a fault code.
I had an overheating problem caused by a blockage in the water intake, but it was hard to diagnose because there were no fault codes.
backfiring speaks of lean... it takes a lot more fuel to nail 3k rpm under load than not...
After that get your multimeter out and start testing the sensors for faults.
Its most likely something that was tweaked after the engine work.
You have probably already seen the faults list, but if not, look here:
In some engines, there are faults that will activate the Engine Guardian (limp mode) but do NOT record a fault code. For example, if my 496 has an overheat in the Exhaust Manifold Cooling Temp (EMCT) circuit, it won't record a fault code.
