Boat is out of water..is staining on drive units normal and ok? And how is hull paint look?
So boat is pulled out, is the staining on drives ok? Also should I paint where some of the black paint was taken off by the muffle when it was being winterized or is it not a big deal? Its a fresh water boat. Also How does the hull paint look it was in the water 7 months? to me it looks fine but have no experience at all with hull paint.
anodes looked fine and were done last year.
pics attached.
eriance at all with hull pai
pics attached.
One item of concern: your hull bottom paint goes right up to the edge of the outdrive. It's bad to have electrical continuity between the paint and the drives. To minimize corrosion, you need a 1" stripe of unpainted fiberglass between the drive and the bottom paint.
Other than that, your bottom paint is in great shape!
ok..will scrub the drives clean and use some touch up paint on them when I get a chance.
That's an interesting way of getting the boat out of the water for storage. Never seen that before.
Its actually a good idea on the marinas part, since it keeps the snow off the boats, and means I dont need a trailer
I think its mostly grime, where they wiped it off to put in the antifreeze is all shiney black.
When the ice freezes I will go and have a look at it and bring a brush and some towls and see if its grime and needs painting
