Winter Projects
Hello all! This is my first post on the forum. I must say this is one awesome forum and I have learned so much here. I upgraded from a 96 Larson 250 to a Rinker 280 EC. We love our new boat and the extra space and amenities! I was wanting to work on a few things this winter while she's tucked indoors.
1. I would love to upgrade to SmartCraft guages. Wanted to see what kind of job this is and if I have someone do it, what kind of charge should I expect to have it done? My speedometer and trim guage currently don't work. I have been using the gps for speed and I'm guessing I have a bad sensor on the lower unit for the trim guage. Wanted to see if anyone has done this and which guages they used. I wanted to be able to keep all my guages looking alike.
2. The Ritchea compass that's built in the dash is broke. What size compass can I put in its place? Or are those all pretty well standard?
3. Some of the light bulbs are out in the cockpit lights along the floor. What size bulbs are those? And how do you get the old ones out?
4. I have the ice maker option in the cockpit, but it does not make ice. The freezer part works and the water line is all hooked up. Is there a water cut off somewhere or something I may be missing?
sorry for so many questions for my first post. Can't wait to get a few things done this winter to be all ready for spring. I appreciate any input anyone has, or other suggestions or upgrades to the 280s!!
thanks!!
thanks!!
The speedo may not be working due to a blocked pick up on the drive.
If you're considering SmartCraft gauges, also take a look at VesselView. The wiring is not much different, and it has a lot more functionality. However, the mounting is different so you would need a custom mounting panel.
On the ice maker: I've never seen one with a separate water cutoff valve. You might have either a blockage in the line or a problem with the control valve.
To be honest, I mostly use my ice-maker as a freezer to store ice that I bring from home. (I'm picky about what goes in my drinks!) On rare occasions, such as when I'm anchored out for multiple days, I'll use the ice-maker to make ice for the cooler. But if my water supply quit and the freezer still worked, I probably wouldn't spend to fix it.
Keep the questions coming! We're here to help.
If your boat has digital throttle and shift (DTS), you already have a SmartCraft junction box at the helm. If not, you'd need to run a cable up from the engine. The hardest part is figuring out the parts list. If you don't want to hire a pro, call Mercury and talk to their techs. Mercury is notoriously bad about publishing info on the web, but I've heard their phone support is good.
The compass, they do have different sizes, but I believe there are like 2 different standards. It's a pretty easy changeout. (just make sure you get one with the correct backlighting)
