Gelcoat cracks below non skid
I am considering buying a 2001 Rinker 340 on a freshwater lake with about 310 hours on its 2nd owner. Before I drove 575 miles to look at it, I asked about stress cracks and damage and was informed of only a semi circle chip in the cabin entry door. When I arrived, I noted a what appeared to be a 25'+ stress crack on the port side only with some spider cracks below the stress crack line just below the non skid but several inches about the rub rail on an inside radius. There was also a crack in the head/shower liner in an upper corner not far from the exterior damaged area. The broker's own gelcoat expert said the interior crack was a repair with mis-matched gel coat that had cracked again. The exterior appeared to be similar to an impact or flex crack with no specific point of impact visible. All rails are straight. Anyone have a similar issue? My fear is if it is fixed that it may reappear if the hull flexed much. Thanks. Paul
There's a decent list of accredited surveyors here:
https://www.boatus.com/insurance/survey.asp
I just came across this on the web, a lot of good info.
http://www.ericgreeneassociates.com/images/Composite_Boat_Damage_Assessment.pdf
Good luck with your search, this forum is a great place to bounce possible purchases to for advice as I did when I bought mine!
