ECOVAC vacuum toilet
frenchship
Member Posts: 1,079 ✭✭✭
Hi
Our Rinker 300 express 2007 has an ecovac vacuum toilet model SO-148 the vacuum pump was installed on the r.h.s. between the exterior hull and the cockpit interior where the driver seat is the only access is under the seat by a panel about 8"x8". I guest the system was installed before the deck was put in. Anybody has any idea how to get to the system to repair it or any idea to replace this system.
Thanks
Paul
Québec ,
Canada
Best Answer
Dream_Inn Member, Moderator Posts: 7,869 mod
Well, I just had fun in the middle of our vacation getting access to our Ecovac. If you have a fridge &/or icemaker on that same side, you will probably need to pull that out to get at it. Mine was drawing a suction. I first pulled the cockpit fridge out to find a barrier wall, so put that back in and then pulled the icemaker. The admiral said she was thankful I hadn't grown a beer belly (I drink lots of rum
) ) cause the area was very tight getting into. I access two duck bills (kind of like the joker valve) and found, well, something like a peanut holding one open. I cleaned both of them and lubed them up with WD40 & they were as good as new. I'm going to order 2 new ones so I have them. Dream 'Inn III -- 2008 400 Express
