Search light wiring 260 EC
I am looking to snake a wire from the bow, bow rail to the inside of the boat
I don't see any panels or acess Any tips ?
I was thinking to run to the back of the boat and pick up the spare Acc wires
Prewired for search light in dash ? Maybe there is a switch electronics?? And 3 Acc switches
Exactly, remote control mounted at the helm to turn on/off and rotate. The spotlight has it's own built in switch that obviously talks to the controller. So all you have to do is get the wires to the spot light. Many boats are already pre-wired, so have a look around the area, you might find some wires.
Greg do you know where they would have run those wires?
With a fixed-mount searchlight, you'll probably find it impossible to accurately aim the beam. In most conditions, the boat moves too much, and the remotes are too slow and hard to use. A handheld would be more effective, not to mention cheaper and easier. Also, unlike a fixed light, you can point a handheld any direction -- astern, into the engine room, or wherever you need it.
Fixed-mount lights make sense on big boat where the captain is piloting from an enclosed cockpit and can't use a handheld. On an express cruiser, they just aren't as useful as you might think.
Thanks
