Paint bubbling and cracking on radar arch
Peg_O_My_Heart
Member Posts: 30 ✭✭
I have a 2002 Rinker FV 310. Paint on the radar arch is bubbling and cracking. I have seen other posts on this forum, but not a sure solution that has been successfully accomplished.
I would like to spot repair the areas in the spring. While doing that, I would reattach all the screws and such and caulk them to prevent water getting in, which I believe is one reason the paint is bubbling in the first place.
I would like to hear from anyone who has tried this or has ideas on how to get it done. My overall goal for this project would be to keep as much water out of the boat as possible when the camper top is up.
Thanks!
Thanks!
@Peg....regarding caulking. I suggest that you caulk the upper end of your arch support where it meets the hull and the two sides but not the bottom. When talking about this with Randy Rinker he said to NOT caulk the lower end of the arch, facing the stern or I'd trap water inside the arch and create corrosion and fiberglass hull de-lamination.
I'll see if I can find the pictures I sent to Rinker to make sure I hadn't voided my warranty. Because my boat was an EC 360, the hard top was shipped separately and was installed at the dealer. The dealer did not caulk the hard top to hull joint, so I did it after consulting with Randy. Pics may be coming!
Regarding arch touch-ups, I watched one being done over several days. It was sanded, the metal was neutralized with something, a spray primer was put on and then the final coat of spray. It was done by a guy using a small compressor and mini spray gun and afterwards you could not tell where he had been painting. I talked with him and he said the biggest trick was to match the color as even the whites fade, sometimes it took him a few test tries. He also said he was lucky that the arch had not pitted so he did not have to use glazing putty. He did say that it was important to neutralize the surface "corrosion" on the aluminum, which presents as a white chalky dust, I guess like efflorescence?
Found the pictures of how Randy Rinker said to caulk the hard top to hull joint to maintain warranty - you'll note the bottom edge (down slope) towards the stern has been left un-caulked to permit water/condensation to run out.....Good Luck!
We had the same problem on our 312, because there aluminum it apparently happens I was told the issue was the stainless steel fasteners being in contact with the aluminum arch. We had a company fix it for us at a cost of $400.00 with the repaint. When I reinstalled all the Bimini snaps on my arch I applied tefjel to all the threads generously installed nylon washers never had problem since
@bella-vitadoes your arch fit that tight to the hull - isn't there even a small a gap between the two?
When our was dune they painted on the arch and we couldn’t tell the difference
