Low cost lighting idea.
dalek
Member Posts: 260 ✭✭✭
What do you think?
Remote control LED lighting in any colour. Bright enough to read by. If anyone is interested I can post a list of parts.
If I have not made anything clear or can be of any further help please do not hesitate to ask.
Very nice Dalek. I've used the same lighting around my hardtop. I will say, the only issue I've had with it is on 12VDC. I needed to add a capacitor across the input power because every now and then I had to reset it to get the remote to work. I've also used the same lighting around the ceiling in my home kitchen.
Really good!
I did try to use those strips under and around my swim platform the problem was that the sticky tape supply with those strip is not good enough and not waterproof. I finally use 4200 sealant,and make sure that all electrical ends connections on the strips are seal with 4200 otherwise water will get into them. Still the actual plastic that cover the LED will get foggy under water. So I end up putting them on the transom above the sterndrives.
Do you think under those conditions the plastic will get foggy?
