Replacement door gasket for Tundra T42 fridge?
Before I go to the expense and pain of replacing the fridge in the galley I think I'd like to try replacing the door gasket. The units freezes up a lot which could mean a bad thermostat or just a bad seal. Since it's really good a making a solid block of ice out of the freezer I think the compressor is fine. I was able to find a whole replacement door for the fridge on Great Lakes Skipper, but have not had much luck on the gasket. Has anybody replaced one of these?
@Stodge, when I decided I had better check the fridge in the cockpit too, the door was working well enough to turn off the interior light BUT I was still worried that the seals might not be tight enough.
So I waited until it was dark then I put a powerful LED flashlight in the fridge and shut the door. That way I'd see if any light was leaking around a seal and if so - where. I was lucky that fridge was okay. At least it made up for the PITA fridge in the cabin
If the fridge is freezing up (meaning there's a lot of ice build up), that is definitely not a thermostat problem. The moisture has to come from somewhere, and the difference between -5'C and -20'C is next to nothing when it comes to pulling that moisture out of the air.
I agree it's because too much fresh air is getting in, either due to a poor seal or the door is opened too frequently and/or left open for too long.
There has to be a cheap way of replacing that gasget. Just call a fridge technician.
