Volvo 8.1 OSI-DF Random misfire
Need some help on this one. Start from cold runs on all 8. Pull out of marina approx. 1000 rpm runs on all 8. Get on plane approx 3800rpm cruise after 10 seconds drops a cylinder. Come off plane and idle on 7, switch off, restart and most of the time it will restart on all 8. 1000rpm back to marina and it will randomly keep dropping a cylinder.
I have so far done the following trying to fix this problem; All 8 injectors rebuilt, 8 new Volvo plugs, all plug wires (Volvo) replaced last year. Could it be a coil pack?
Any suggestions? I am going to the boat tonight to recheck all connections and grounds.
Thanks everyone and hope you are all having a good holiday!!
In all cases identify whats the root cause before you start replacing things for no reason.. Thats what mechanics like to do
Worst case it could be the ECU as well, however the pack swap will show that.
@F1100, I don't know which cylinder is the culprit. I was thinking of replacing 1 pack and keep moving it until it stopped missing. I had the injectors rebuilt as the engine seemed down on power and that fixed the top end speed issue.
Best way however is to do a resistance check..it will 100% show if that coil pack is bad.
find out what the good coil resistance value is..and voila you will easily find the bad one.
Dont just throw money away for no reason, coils can last years and years... it was most likely a faulty winding.
your mechanic sounds like he wants to sell you 8 coil packs instead of one. They can literally last YEARS on low HP applications like these boat engines.
You can't always find a bad coil pack by checking resistance... but the issue you're encountering is most likely a coil pack.
coil packs can be tricky... yours sounds classical... the things are internally isolated with a ceramic like two part epoxy, and when it is cold they are pretty dang sturdy- not demonstrating any issues at all- but when you get them warm? The epoxy separates and allows cracks to form that doesn't isolate the current too well at all, allowing an internal ground to happen. It will only manifest and can only be checked when at operating temperature, and rarely shows anything externally. A resistance check with ye 'ol multimeter will show this, as stated, but not always- to hedge your bets do it when the coil packs are at operating temps and the isolation material is still separated, because when the packs cool and the casing contracts, you'll look right past it.
if you wanna figure out which cylinder, just pull the plugs and observe the tips... your off firing cylinder will most likely have build up the others don't have. If you don't wanna mess with that, as it can be a PITA, simply pull the boots off and hold near intake manifold and see which ones bridge the gap. If you have a competent pilot, you can do this idling back to the marina.
@212, I was also told that with 450hrs the coils could be going bad, so I replaced all 8 coils with GM ones still the same. So far new VP plugs, GM coils, VP plug wires, sea trial tonight, fingers crossed!!! I also had an good conversation with a fuel injector guy in NY. He was saying about a possible bad injector coil when warm/hot and he can bench test the injectors hot. The company who rebuilt mine could not test hot. If the problem is still there tonight I am going to disconnect the injectors one by one until I find the cylinder, easier said then done when out on the water.
On a light note this reminds me of a Blondie song: One way or another I'm gonna find ya
I'm gonna getcha getcha getcha getcha.
Needed some humor this morning!
but another couple things...
injector O-rings are tricky.. if you crushed one while you were installing them, which is silly easy to do, you could have a bad seat and that cold lend to your issue...
or another, and it took me a LONG time to figure this one out-
whether EV6 or EV1 connectors on the injector harness, the blades and spades are easy to bend, and since they are driven off of impedance/resistance, it is incredibly important for the blades to have full seating across the spade- no twist on those blades whatsoever... they are easy to bend while pushing them on to seat, and the bend is easy to miss while inspecting them... make sure the blades are in FULL contact with the female spade... you can pull the spark plug on a cylinder encountering this and there will be zero evidence of over fueling/no burn- because there is no fuel going to it. and the computer thinks it's firing the injector just fine... so.. it's really hard to spot... give it a look see..
in all honesty, and I'm not trying to be a jerk when I say this: Injectors are hearty pieces of equipment with gas engines... they rarely go bad, and they rarely need cleaning... they will last the life of an engine in almost all cases will outlive the engine... however, a lot of subtle things can go wrong when they are messed with. It's really easy to do.
OK here’s the update: Started the engine ran ok from cold. Pulled out of the marina and started to load the engine approx. 1500 rpm had a couple of stumbles onto to 7 cylinders. I messed with the injector harness and connectors problem went away on its own. Ran the boat for about 30 mins at approx. 4k rpm and WOT no issues. The misfire didn’t come back so was it a slightly fouled plug from the possible bad plug wires that cleared itself? I don’t know but will sea trial again this weekend. Thanks you guys for all of your suggestions I really appreciate the support.
Update: Ran second sea trial last night for approx. 30 mins, no misfire and engine felt great running on the numbers that I always see, 3800 rpm 28.5 knots. So far so good will run another sea trial this week, weather dependent and hopefully go away overnight on Saturday!
Thank you everyone for your support and advice.
Update: Sea trial # 2 on Sat. Started from cold left the marina got on plane boat ran fine. Same numbers as before, so we ran for approx. 15-20 minutes at 3800rpm. Headed back to the marina dropped to 1500rpm, then 1000rpm then as normal idle as I maneuver into the marina. Went to turn into our row and low and behold the engine dropped a cylinder for approx. <10 seconds. I went into neutral then reverse to stop the boat back into neutral then the engine came back onto all 8 and never missed again. Tied up in the slip sounded great.
I am going to call a Volvo dealer and have the scan tool diacom hooked up and run the boat. I am at a loss but the whole injector solenoid getting hot theory is sounding that it could be the culprit. Will keep you guys posted.
